ldaps certficate store
Postby sir2u » Mon Oct 11, 2010 9:56 pm
Is there any way to get LDAPS working for authentication? I'm using Tomcat 6 on Ubuntu 10.04. I've managed to get SSL working with APR. I have a working LDAP configuration, and I've set this up with other applications like Cacti and Splunk. All I need to know is can Subsonic make an LDAPs connection? And if so, where is it looking for CA certs?
I'm trying to do a writeup for all this once I figure out this last piece.
sir2u
Re: ldaps certficate store
Postby cybertronian » Tue Aug 23, 2011 2:59 pm
This post is a bit old, but I was also having problems with getting LDAPS working with my self-signed CA certificate.
The standalone Ubuntu/Debian install of subsonic 4.5 uses the default java CA keystore, which is located here on Ubuntu 11.04:
/etc/ssl/certs/java/cacerts
You should already have the CA certificate from the SSL setup of LDAP. The normal location for CA certs in Ubuntu is:
/etc/ssl/certs
If your CA certificate is in a different location, then modify the directions below accordingly. The CA cert has to be in DER format, so if yours is in PEM format do the following first:
sudo openssl x509 -in /etc/ssl/certs/CACERT.PEM -inform pem -out /etc/ssl/certs/CACERT.DER -outform der
Replace CACERT.PEM with the name of your certificate file and CACERT.DER with the name for the DER formatted file. Now you can import the DER formatted CA cert into the main java CA keystore file:
sudo keytool -importcert -alias self-CA -keystore /etc/ssl/certs/java/cacerts -file /etc/ssl/certs/CACERT.der
Again, replace CACERT with the name of the DER certificate file from the previous step. Then restart subsonic:
sudo service subsonic restart
cybertronian
