QNAP NAS and UTF-8. How-To
Postby redranger » Tue Oct 12, 2010 12:58 pm
Hi guys and girls......
My question is quite simple:
- How do I get Subsonic to read `´ ! and other characters.
- Subsonic is running on tomcat on my QNAP
I tried to match this guide, http://kevinmorey.com/post/967347977/fi ... characters, to my QNAP but without any luck.
//// I tried \\\\
* Defining different languages in the subsonic.properties file. With the LocaleVariant=
* Tried to define "LANG=en_US.UTF-8" in the tomcat catalina.properties file.
I don't want a subsonic.sh file to start up with tomcat as stated in other threads here at the Subsonic forum. Unless this is the only way to do it.
The reason that I don't want this is that I fixed the Subsonic home dir problem on QNAP (the var folder is a ramdisk folder) by redirecting the subsonic home folder in the catalina.properties file (tomcat).
So do somewhere at this forum have a good idea on how I can solve this.
Looking forward to hear from you.
Thank you very much.
/\ Keep streaming /\
/Redranger
Thank you for your help.
Regards!
/Redranger
redranger
Postby redranger » Thu Oct 14, 2010 7:30 am
Anyone with a suggestion?
Regards!
/Redranger
redranger
Postby redranger » Mon Oct 18, 2010 8:54 am
Do no one else have this problem?
Hope to hear something soon.
Regards!
/Redranger
redranger
Postby redranger » Mon Oct 25, 2010 9:15 am
Can it really be so that no one else than me has this problem? Hope to hear from someone soon.
Regards!
/Redranger
redranger
Postby redranger » Mon Nov 08, 2010 1:20 pm
Still the issue remains. No one with an idea on how to solve this?
Thank you.
Regards!
/Redranger
redranger
Re: QNAP NAS and UTF-8. How-To
Postby redranger » Mon Feb 20, 2012 10:57 pm
More than a year after....I'll try again.
Anyone?
Regards!
/Redranger
redranger
Postby BKKKPewsey » Tue Feb 21, 2012 3:58 am
What version of SS are you currently running?
Most (if not all) of the issues regarding international characters within SS have been resolved.
However if it is an OS problem then that may not help :?
Postby redranger » Tue Feb 21, 2012 8:26 pm
BKKKPewsey wrote:What version of SS are you currently running?
Hi BKKKPewsey,
Thank for answering, great to see ;-)
I'm running v4.6 beta2
Regards!
/Redranger
redranger
Postby BKKKPewsey » Tue Feb 21, 2012 10:06 pm
That version should be ok.
I assume you have seen viewtopic.php?f=2&t=8254&hilit=international+characters#p33296
Not sure if that helps with your OS :?
Postby redranger » Wed Feb 22, 2012 8:22 pm
Hi...
I don't have the subsonic.sh file. I'm running the WAR distribution on my QNAP (firmware v3.6). Is it possible to set these same parameters for the WAR deployment?
I use the catalina.properties for setting a different path for subsonic, than VAR as this folder is cleared on reboot on the QNAP. Could this file be used?
Thank you.
Regards!
/Redranger
redranger
Postby BKKKPewsey » Wed Feb 22, 2012 8:33 pm
I am afraid you may to have to wait for another QNAP user to answer that
Assuming there are any - with the responses so far :?
(That's the one advantage of Windows - that great technical resource called Google can usually answer anything :lol: )
Postby redranger » Wed Feb 22, 2012 8:36 pm
BKKKPewsey wrote:I am afraid you may to have to wait for another QNAP user to answer that
I'll try to patient ;-) and wait for another QNAP user to answer.
Thank you BKKKPewsey.
Regards!
/Redranger
redranger
Postby redranger » Mon Nov 04, 2013 10:19 pm
Any news on this? Is this not possible to fix on the QNAP runing WAR on Subsonic?
Regards!
/Redranger
redranger
Users browsing this forum: Google [Bot] and 17 guests
