admin log in not working
Postby mcm268 » Fri Oct 15, 2010 11:43 am
I recently downloaded and it said to go to http://localhost and log in using admin admin and it tells me wrong user name or password
mcm268
Postby nipar » Sun Nov 14, 2010 7:30 am
you need to login at http://localhost:4040
":4040" is the port number where your webapp subsonic is.
If you need more help, I suggest you be very detailed in posting a problem.
If I assumed too much with my reply, I apologize.
nipar
Postby alphawave7 » Sun Nov 14, 2010 7:49 am
It's been a while, but try admin as psswd only, leave user blank. Try the reverse if no werkie. G'Luck!
