Mac OSX subsonic-4.1.pkg error message after installation
Postby chryslerpetz » Sat Oct 16, 2010 2:49 am
Your help would be appreciated.
After downloading and installing the subsonic pkg on my Mac Mini OSX 10.5.8, the icon jumps on the dock for about 30 seconds and then this error message pops up...
Uncaught exception in main method: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'controller' defined in class path resource [applicationContext-mac.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [net.sourceforge.subsonic.booter.mac.SubsonicController]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: java/awt/TrayIcon
I've checked in system preferences to make sure there aren't updates that haven't been installed but everything is up to date. I have to confess that I'm not an advanced user.
Thank you in advance.
chryslerpetz
Postby TheGunslinger » Fri Dec 10, 2010 2:02 pm
If I had to guess, not only are you running 10.5.8 but you are running it on a PPC mini and not an Intel mini?
If that's the case, removing Subsonic (throw it in the trash and then empty the trash) and downloading and installing version 4.0.1 should do the trick and would probably be the easiest for you.
You can also look at this post here: http://forum.subsonic.org/forum/viewtopic.php?t=4304
TheGunslinger
