JVM could not be started error after Java update
Postby luckycat007 » Tue Oct 19, 2010 12:42 am
I get an error message "The JVM could not be started. The maximum heap size (-Xmx) might be too large or an antivirus or firewall tool could block the execution" when I try to start Subsonic Tray Icon. However the service seems to be started OK, as I can play media from my server remotely from my Android.
THis started happening after updating Java recently. I do not think it's a firewall issue but I will try to confirm that is not the case.
luckycat007
Postby kermit22 » Tue Oct 19, 2010 6:29 pm
If you are on Vista or 7 you might have to start the tray icon in administrator mode. If nothing else you will be able to rule out a permissions problem.
kermit22
Postby hollowpoint » Wed Oct 20, 2010 5:43 am
solved, good call kermit
hollowpoint
Postby wor2k » Fri Feb 18, 2011 7:59 pm
I just updated my Subsonic and I'm getting this exact same error. I have no firewall software and I have disabled all windows firewalls and I tried running Subsonic service as Administrator. All coming back with same problem. Subsonic ran flawlessly before update. Any suggestions??? Thanks in advance.
wor2k
Postby jeffcavicchi » Sat Feb 19, 2011 5:09 pm
Several problems seem to have cropped up since Java updated - for a week or so I couldn't get to Sourceforge using Chrome because of a Java error (since resolved).
Hopefully this stuff will get resolved in the next version of SS.
jeffcavicchi
Solved
Postby glfrancisco » Sat Apr 23, 2011 7:02 am
jeffcavicchi wrote:Several problems seem to have cropped up since Java updated - for a week or so I couldn't get to Sourceforge using Chrome because of a Java error (since resolved).
I uninstalled Java and Subsonic, just ran the Subsonic which reinstalled Java ans it just worked.
glfrancisco
Re: JVM could not be started error after Java update
Postby duckdown » Tue Sep 20, 2011 9:49 pm
I'm having this problem after updating Java too
What do I do?
Windows 7, 64bit
Thanks all
duckdown
