Changing Subsonic folder
Postby Smir9 » Thu Feb 22, 2007 9:25 pm
Is there a way of changing the c:\subsonic folder to a custom on?
I have a small boot partition and there's no space in c: for subsonic...
Smir9
Postby sindre_mehus » Fri Feb 23, 2007 1:24 am
Certainly. If you have installed Tomcat as a Windows service, please proceed as follows:
1. Open "Start > All Programs > Apache Tomcat 5.5 > Configure Tomcat"
2. Select the "Java" tab.
3. Add "-Dsubsonic.home=c:/foo/bar" to "Java Options"
4. Restart Tomcat.
Hope this helps,
Postby matthew » Fri Feb 23, 2007 8:06 pm
Along the same lines - Is it possible to change the name of the web folder so that instead of going to http://localhost/subsonic, I can goto http://localhost/music ?
thanks
Matthew.
matthew
Postby sindre_mehus » Sat Feb 24, 2007 2:25 am
Yes. Just rename subsonic.war to music.war before deploying it. (Remember to remove the old webapps/subsonic directory and war file, otherwise you will have two instances running).
Postby matthew » Sat Feb 24, 2007 2:33 am
sweet. thanks sindre!
Matthew.
matthew
Postby jman » Sat Mar 17, 2007 11:43 am
sindre_mehus wrote:Certainly. If you have installed Tomcat as a Windows service, please proceed as follows:
4. Restart Tomcat.
Hope this helps,
I've installed tomcat as a windows service, but that does not make it available from the start menu. Are you referring to a windows installer?
I've tried several approaches to add a -Dsubsonic.home environment variable through the tomcat admin web interface. Is there a way to to do it there or alternatively manipulate the "Java Options" you refer to directly in the tomcat distribution files?
Another possibility would of course be to install tomcat with a windows installer. However, the distribution I have downloaded does not seem to have an installer.
/Jon
jman
Postby sindre_mehus » Sat Mar 17, 2007 12:47 pm
Hi Jon,
Tomcat provides three kinds of distributions: zip, tar.gz and "Windows Service Installer".
The latter is the one I'm referring to. And yes, it's a windows installer. If you install the zip or tar.gz version you have to modify the startup scripts in TOMCAT_HOME/bin. There is no way to change it in the admin web interface. The easiest approach is using the windows installer.
Hope this helps,
Change subsonic.home
Postby jman » Sat Mar 17, 2007 1:03 pm
Found the answer myself. For all others having trouble with the same issue:
Add the system environment variable:
value: -Dsubsonic.home=x:\foo\bar
PS: Remember to open a new instance of Windows Command Promt to make the new variable "visible"
I think this approach only works if you start the tomcat server using startup.bat (and not if you are running it as a windows service)
jman
Users browsing this forum: No registered users and 87 guests
