listed music folder, but not showing up in apps
Postby minieod » Wed Oct 20, 2010 6:47 am
Hey guys. Ok, background: I am running EVO 4G with android 2.2. and also running my server from my mac 10.6
now the issue:
everything is set up properly, at least i think. I have an enormous music folder where everything is kept, i dont put each band in a folder, with an album inside that, and so forth. ive been keeping a neat mp3 collection for 10+ years and its all song by song, but very organized and labeled
anyways. my folder is /Users/Mike/Music (the default mac music folder) and that is what is listed in my localhost settings on server side, i am linked to it on the phone, because i can see the - few - small folders that i do have... and i can access their contents and play the mp3s / wavs/ whatever file
but i cannot see any mp3 outside of that folder, any song file located in /Music will not show itself.
since there are over 8000 songs, is it just taking a while to "load" or is there an error
any help would be great, thanks!
minieod
Postby stennie » Wed Oct 20, 2010 3:31 pm
From my experience with the Android app and Windows server, any MP3s in the root of your chosen directory will not be shown. I only see the subfolders of the root of the share, and I can see any music files in those folders. This is the case for both of my shares, and does not appear to be the behavior of the web interface -- only the Android app.
I can't speak to the iPhone apps, however.
So, yes, the following example appears to be normal behavior:
Share: X:\music
Any FILES in X:\music will not be shown
Any SUBDIRECTORIES in X:\music will be shown
Any FILES IN THE SUBDIRECTORIES of X:\music will be shown
My recommendation would be to change your chosen directory to /Users/Mike then select the "Music" in the app.
stennie
Postby minieod » Wed Oct 20, 2010 5:44 pm
weird , i wonder why they do that....i guess i should make /users/mike the music folder, and just open /music from there
or ill have to make a separate folder and movei t all there
minieod
