Random albums update
Postby breakolami » Sun Oct 24, 2010 11:27 am
Hello
On main frame we have random albums displaying with update every 20 seconds
How can I change update time ?
breakolami
Postby breakolami » Sat Oct 30, 2010 8:01 am
Allo can I change that ?
breakolami
Postby supra92 » Sat Oct 30, 2010 10:20 pm
Hi breakolami,
You sure can. All you need to do is edit the "home.jsp" file, which is located in $SUBSONIC_HOME/WEB-INF/jsp/ For my Linux/Tomcat install, this is /usr/share/tomcat6/webapps/subsonic/WEB-INF/jsp/
Open up "home.jsp" in vi or whatever text editor you like. Look for the following line, which for Subsonic 4.1 is Line 8:
<meta http-equiv="refresh" content="20">
Just change that 20 value to however many seconds you'd like between album art updates. I just changed mine to "30" and it now refreshes every 30 seconds as expected. Don't forget to restart tomcat/jetty/etc. after you edit/save that file.
Hope this helps, and let us know if it works for you.
Supra92
supra92
Postby ScaredyCat » Sun Oct 31, 2010 8:44 am
Thanks for that.
I found it really annoying when trying to go through and replace cover art. I guess it really should be an option, but this manual fix is good for the moment
SC
ScaredyCat
Postby breakolami » Sun Oct 31, 2010 9:55 am
Thanks for that
I go immediately make this change :wink:
breakolami
