home screen
home screen
Postby acacia68 » Tue Oct 26, 2010 12:49 am
when i am on desktop home screen or android app and select random or newest it says no music found or displays nothing
acacia68
Postby GJ51 » Tue Oct 26, 2010 12:06 pm
If you're sure eerything else is installed properly, and your directory locations are properly defined in the settings, I would suggest uninstalling and reinstalling Java. I've cured a few anomolies doing this recently.
http://www.java.com/en/download/manual.jsp
Direct link to all Java OS versions. Be sure to install both 32/64 bit if you use a 64 bit Windows OS.
