Missing Options
Missing Options
Postby Noxton » Fri Oct 29, 2010 1:31 am
I am completely lost.
I am on a Win7 32-bit machine. My friend has a server with an older version of subsonic, and I have 4.1. As you can see, there is a menu bar listed on his that is not on mine. It doesn't matter what theme I use, his works, mine doesn't.
His:
Mine:
Anyone have any ideas? He said he made no changes and that he just installed it. I did the same.
Works GREAT other than this!
Noxton
Postby GJ51 » Fri Oct 29, 2010 8:32 am
Somehow, you turned on "Party Mode" which simplifies the interface.
Go to Settings, Personal, scroll down to the entry for Party Mode and uncheck the box.
Postby Noxton » Fri Oct 29, 2010 12:19 pm
Whoops. Thought I was keeping my playlists safe when I installed, not realizing that I was stripping myself of utilities...
Thank you so much!
Noxton
