.war deployment and /var/subsonic/*
Postby jerbear1337 » Mon Nov 01, 2010 7:27 am
I am attempting to deploy subsonic.war on a private JVM with my current hosting (http://www.mochahost.com/java.php) "business plan" . The issue I am running into is errors telling me that /var/subsonic directory does not exist. The problem is my hosting is setup such that my access is within.. /home/USERNAME/* So i clearly have no ability or access to make /var/subsonic/*. Is there any easy way for me to change it so that instead of /var/subsonic it would try to use directory /home/USERNAME/var/subsonic instead? :?:
Jeremy
jerbear1337
Postby jerbear1337 » Wed Nov 03, 2010 1:56 am
willing to recompile the source if someone can point me in the right direction as to what i need to change pleasE!!!!
jerbear1337
Postby baaldemon » Thu Nov 04, 2010 5:03 pm
You will need to modify the source and recompile. The home directory is in the net.sourceforge.subsonic.settings.SettingsService class. Just modify that to where you want the home directory to be and you should be good.
baaldemon
