subsonic stopped working(linux)
Postby Sherlock19 » Tue Nov 02, 2010 1:05 am
i currently use ubuntu 10.10 64 bit?(im pretty sure that the 64 bit is right but id love to know how to check XD)
subsonic worked great then suddenly stopped working, could it be from me always updating my machine?
if you need any more info from me i will give it but please be specific.
please and thank you!
Sherlock19
Postby oeh » Tue Nov 02, 2010 1:25 am
Hi there.
Good place to start is here
I terminal type:
you@xxxxxxx:~$ sudo service subsonic status
this will give you the Subsonic server status.
in the command you can replace status with:
start
to start the server if it isn't running
stop
to stop the server
restart
to restart the server
force-reload
to force the server to load it selves again.
one thing to do is to have a look at the log in:
/var/subsonic/
Regards
OEH ;-}
oeh
Postby Sherlock19 » Tue Nov 02, 2010 1:44 am
well i checked the staus of my subsonic, and it was running, i also forced a reload and still nothing.
this is the error i recieve in my browser
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
any other ideas?
Sherlock19
Postby Sherlock19 » Tue Nov 02, 2010 1:53 am
# (/etc/init.d/subsonic)
# For example, to specify that Subsonic should use port 7070
# and use a Java memory heap size of 80 MB, use the following:
# SUBSONIC_ARGS="--port=4040 --max-memory=10000"
there is my config file, anything else you want?
all of my ports are forwarded as tis program did work then all of a sudden stopped.
Sherlock19
