javascript:noop(), subsonic won't play
Postby berndwinkler » Tue Nov 02, 2010 7:44 pm
I installed subsonic on ubuntu on my vps, works just fine...usually. I access it from various workstations, usually with Firefox. On the current Workstation (Vista with Firefox) my statusline says "javascript:noop()" when the mouse is hovering above the "play" or "Add to playlist" - Buttons. When pressing "play", the current title is added to the playlist, but not played. Pressing "add" works as it should, it adds the current title to the playlist.
I have the current flash version installed, and javascript ist turned on. I opened Internet Explorer simultaneously on the same PC, and with this, subsonic ist working just fine. So... it must be a client-problem. Any idea?
Thanks in advance!
berndwinkler
javascrip:noop()
Postby jeremy_loo » Mon May 09, 2011 7:39 am
Hi berndwinkler,
I'm having the same issue on my audio file but not video.
Have you got this solved.
Jeremy
jeremy_loo
Postby joeman2116 » Wed May 25, 2011 4:45 am
I am getting the same error on any mp4 videos i hover over
joeman2116
