transcode problem FLAC -> mp3 Lame
Postby theseal » Thu Nov 04, 2010 9:16 pm
Version 4.1 (build 1806) – September 10, 2010
Server jetty-6.1.x, java 1.6.0_17, Linux (72.7 MB / 86.2 MB)
LAME 32bits version 3.98.4 (http://www.mp3dev.org/)
FFmpeg version 0.6, Copyright (c) 2000-2010 the FFmpeg developers
when transcoding from FLAC to MP3 the bitrate do not change, but it LOOKS as if is an MP3 file, atleast in the webplayer, and my Isub plyas the file.
I get the following error in the log.
DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) fatal error: can't update LAME-tag frame!
theseal
Postby kapz » Fri Dec 03, 2010 9:41 pm
Paid Subsonic user
Love my unRaid (~9.5TB): [url=http://lime-technology.com/forum/index.php?topic=2031.msg40351#msg40351]Pictures Here (Reply #82)[/url]
kapz
Postby stozher » Sat Dec 04, 2010 11:52 am
One step transcoding SS 4.1 ("-ar" is a sample rate, "-ab" is a bit rate, "-ac" is a channels (2 for stereo) and "-map_meta_data" transfer all tags from FLAC to MP3):
ffmpeg -i %s -f mp3 -ar 44100 -ab %bk -ac 2 -map_meta_data 0:0 -
SS 4.2 don't parse correctly %b options and workaround is to use fixed bitrate (change "192k" by your choice):
ffmpeg -i %s -f mp3 -ar 44100 -ab 192k -ac 2 -map_meta_data 0:0 -
stozher
