Connection Issue
Connection Issue
Postby cundo » Sat Nov 06, 2010 2:34 am
Hello everybody, I've been using Subsonic fowarding my server to the port 80 successfully until my trial period expired, now I've a license and I cannot find out my server into internet...
I don't know what happened...I haven't an error, I've tried to check out if the trouble where in my Router so I've set up the server into a DMZ and still won't see where is the fail.
Network Settings messages:
Status: Successfully forwarding port 80.
Status: Successfully registered web address.
Thanks to help me,
Regards!
cundo
Postby GJ51 » Sat Nov 06, 2010 9:28 am
I would try a different port. Some ISP's block 80 if they see traffic on it.
Postby cundo » Sat Nov 06, 2010 6:29 pm
GJ51 wrote:I would try a different port. Some ISP's block 80 if they see traffic on it.
Nothing happen, I change port and nothing happen, my Subsonic subdomain is redirected to my Internet IP...but I can Acces in my LAN...
cundo
Postby GJ51 » Sat Nov 06, 2010 6:49 pm
Do you have port forwarding set up properly on your router?
Postby cundo » Tue Nov 09, 2010 4:07 pm
GJ51 wrote:Do you have port forwarding set up properly on your router?
Yes, i've port forwarding on my router, It was working very well until 10/30/2010 where my trial period expired for subsonic subdomain.-
I was listening music with Android App redirecting my Dynamic IP to NO-IP domain...
cundo
Postby GJ51 » Tue Nov 09, 2010 7:22 pm
The Android app requires you to make a donation and enter the license information into the server after the trial period has expired.
