ConnectTimeoutException
Postby ramskip » Wed Nov 10, 2010 9:54 pm
Status: ramskip.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
I keep getting this error when trying to "Access your server over the Internet using an easy-to-remember address."
I'm using port 80 and have manually forwarded it. I've also tried port 1025 as an alternative with no luck. I used PFPortchecker to confirm that my ports are actually open.
I've also tried this with the "Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding)." button checked and not checked.
Any help here would be GREATLY appreciated, burned a good part of my day trying to get this to work. Been trying to get this running now for about 2 hours, why is this so hard!?
thanks,
d.
ramskip
Postby GJ51 » Wed Nov 10, 2010 10:32 pm
If it was easy, everybody would be doing it.
There are a couple things you can do. Check your router or use a web site that identifies your external IP address issued by your ISP.
Then try to access SS by using the IPaddress and the port #
e.g. http://285.27.18.56:80
If that doesn't work, something is not set up right. I usually stay away from port 80 because many ISP's block it or use it to manage your gateway device. I typically use 8080, 8081, etc.
RESOLVED!
Postby ramskip » Thu Nov 11, 2010 2:51 am
Thank you SO SO MUCH! That totally did the trick. Port 8080 works like a charm and I absolutely had to use my IP address rather than the shorthand version.
Can't wait to check this thing out, yesss!!
d.
ramskip
Postby GJ51 » Thu Nov 11, 2010 5:55 am
It's the best! Enjoy SS.
Congrats on getting it running.
Just remember that your ISP can change your IP address from time to time. I don't think it's that much of an issue anymore, I've had the same IP for over a year now, but it can happen. When it does, just do the same thing and use the new IP address.
