Can not connect
Can not connect
Postby thedecline13 » Fri Nov 12, 2010 3:04 am
My SS was up and running fine but now I can not connect to it. My ip didnt change. It will not even connect locally. How can I fix this? any help please.
thedecline13
Postby thedecline13 » Fri Nov 12, 2010 3:20 am
is subsonic down?
thedecline13
Postby alphawave7 » Fri Nov 12, 2010 4:36 am
Try stopping and restarting your server.
Postby thedecline13 » Fri Nov 12, 2010 5:10 pm
restarted my server and that didnt help. Why wouldnt I be able to get to my local subsonic?
thedecline13
Postby ootuoyetahi » Fri Nov 12, 2010 6:52 pm
thedecline13 wrote:restarted my server and that didnt help. Why wouldnt I be able to get to my local subsonic?
Try restarting the service.. What OS is it running on?
ootuoyetahi
Postby kermit22 » Fri Nov 12, 2010 7:41 pm
Are you trying to access your server with your xxxxx.subsonic.org address? If so try using http://localhost:port number or the ip address of your pc followed by the port number. So if you are running subsonic on port 4040 the address will either look like http://localhost:4040 or http://192.168.X.X:4040
kermit22
Postby thedecline13 » Sat Nov 13, 2010 1:42 am
im running snow leopard server 10.6.4.
I've tried 192.168.1.xxx:4040. I get an error cant find server.
I try my sub name thedecline.subsonic.org and it brings me to the main subsonic page.
I deleted the subsonic app and the app support folder. Reinstalled and that didnt work.
restarted apache that didn't work
i cant understand why local will not work
thedecline13
Postby GJ51 » Sat Nov 13, 2010 2:39 am
I get your log in screen. Works from here.
Postby thedecline13 » Sun Nov 21, 2010 4:20 am
I fixed the problem some how the subsonic folder in the application support folder was empty. once i reloaded it, it work.....
But I just updated to 10.6.5 it broke the connection again. I check to see if the folder was missing or incomplete but everything is there. Back to the drawing board again.......
thedecline13
Postby thedecline13 » Sun Nov 21, 2010 4:39 am
ok figured it out... subsonic app has to be running all the time.. I set the app to open at login
thedecline13
