Wma still not playing..
Postby daniell » Tue Nov 16, 2010 8:09 am
Have tried everything now, and still not able to play wma files larger than 128 Kbps.
I see here that some people use "wmadec" in transcode line..
Is the wmadec a part of ffmpeg !! or do i need to install separately on my Centos Server.. if so, what files to install ??
Thnks
Supermicro Intel(R) Core(TM) i7-3555LE CPU @ 2.50GHz, 4 cores 8gb ram
CentOS Linux 6.6 Server, jetty-6.1.x, java 1.7.0_71, Linux (143,2 MB / 437,5 MB) Subsonic 5.1
Supermicro Intel® Atom™ D510 4gb ram
Sophos Security Gateway UTM /v9
daniell
Postby daniell » Wed Nov 17, 2010 4:00 pm
Rely, nobody knows this ??
daniell
Postby Exrace » Thu Nov 18, 2010 4:11 am
Might be the version of the ffmpeg on your server.
It should support wma with no issues.
I am running on a windows box right now and it works OK with wma
Exrace
Postby GJ51 » Sat Nov 20, 2010 6:09 am
Anybody know the way to upgrade to the latest ffmpeg without causing damage? I'd like to see if it solves an issue with playing video in SS.
Thanks for any hints.
Postby Exrace » Sat Nov 20, 2010 1:42 pm
Since it is just command line I would confirm if the new version uses the same command line set. That open source project I don't think would release a version that was not backward compatible.
Exrace
