subsonic.org links but to wrong path
Postby zanco » Thu Nov 18, 2010 8:59 am
a collegue als has installed subsonic on Server 2003. All works great when pointing the browser to the local server. The url hisname.subsonic.org however points after logging in to a wrong path, http://87.211.xxx.xxx:4040/sharesMusic/ instead of /shares/Music
Local connnection or remote connection to http://87.211.xxx.xxx:4040 gives the right path after logging in.
Any help how to solve this ?
TnX,
Ben
zanco
Postby GJ51 » Thu Nov 18, 2010 9:05 am
Open the tray icon on the toolbar, (right-click), select the settings tab, check to see what if anything has been entered into the context path.
I'm not too sure how it works, but I've always used the default " / ", if there is something different there you might try resetting it.
Also check Settings, Music Folders for any path typos.
Postby zanco » Thu Nov 18, 2010 2:19 pm
GJ51 wrote:Open the tray icon on the toolbar, (right-click), select the settings tab, check to see what if anything has been entered into the context path.
Thanks a lot ! He just thought he had to enter the path to the music files there also.
All works now,
Big Thanks !
zanco
Postby GJ51 » Thu Nov 18, 2010 2:39 pm
You're entirely welcome.
Happy to be of help and glad to see you've got it fixed! :D
Users browsing this forum: No registered users and 61 guests
