Subsonic delete albums from searchindex when indexing.
Postby kroken » Tue Nov 23, 2010 1:33 am
Well this is strange, if i look in the log i see something like this " delting logically info about bla bla bla c:\2\musik\bob dylan\album cant find on disk" but its there, whats the problem with this?
kroken
Postby Exrace » Tue Nov 23, 2010 5:39 am
I have seen this hit on some of my dirs after a upgrade but next run it is OK. Maybe a bug?
Exrace
Postby kroken » Tue Nov 23, 2010 1:26 pm
Exrace wrote:I have seen this hit on some of my dirs after a upgrade but next run it is OK. Maybe a bug?
Yeah its a bug, next run didnt fix the problem so i had to remove the searchindex myself.
kroken
Postby BlueScorpion » Wed Mar 16, 2011 9:40 pm
My Subsonic installation still has this problem, Version 4.4.
The albums still there on disk and I can search them manually, but they can't find out via searchindex.
Is there any solution for this?
thanks
BluE
http://drehmomente.com.de
BlueScorpion
Postby GJ51 » Thu Mar 17, 2011 4:46 pm
Try a Java uninstall/reinstall to the latest version(s).
http://www.java.com/en/download/faq/java_win64bit.xml
