Need help. Subsonic on Windows7
Postby Exrace » Thu Nov 25, 2010 2:14 pm
Subsonic is a web app.
You need to go to http:\\mypc to see the interface.
On the pc you installed it on the control panel app has a link to the instance running on you computer. Default port is 80 so if you have not other apps using port 80 it should work out of the box.
Exrace
