Re-scan music folders / umlaut problem
Postby idkfa » Sat Nov 27, 2010 8:34 am
Hi
First thanks a lot for this nice piece of software :D
But actually I have 2 problems:
1. How I can re-scan my music folders? I have 6 folders with music in it but just the music of one folder is displayed.
2. Is it possible, that there is a umlaut problem? All music (artist, album, track) with an umlaut (ä, ö, ü) in the name don't show up in the library!
Thanks for your help!
cheerio
ps: I use Ubuntu Lucid Lynx and android 2.1.
idkfa
Postby stozher » Sat Nov 27, 2010 1:58 pm
I use Debian testing / UTF-8 locale.
Yes, this is a problem... but workaround found. Rename all folders and track: ä -> ae, ö -> oe, ü -> ue, ß -> ss.
FLAC tags works fine exept for compilation albums. In random frame artist for album isn't a 'Various Aartists' but some artist from compilation. Currently for this album I see 'Eardrop / Progressive Bunker' (correctly: 'Panzar Produktionz / Progressive Bunker' or 'Various Artists / Progressive Bunker' if 'ALBUMARTIST=Various Artists'). TAG example:
ALBUMARTIST=Panzar Produktionz
ALBUM=Progressive Bunker
ARTIST=Eardrop
COMPILATION=1
CONTACT=http://www.panzarproduktionz.com/
COPYRIGHT=Creative Commons Attribution-NonCommercial-NoDerivs 3.0 Unported License
DATE=2010
DESCRIPTION=PP001/2010, http://www.panzarproduktionz.com/
GENRE=Electronic
LICENSE=http://creativecommons.org/licenses/by-nc-nd/3.0/
ORGANIZATION=Panzar Produktionz
REPLAYGAIN_REFERENCE_LOUDNESS=89.0 dB
REPLAYGAIN_TRACK_GAIN=-0.40 dB
REPLAYGAIN_TRACK_PEAK=0.59005737
TITLE=THC
TRACKNUMBER=3
TRACKTOTAL=8
ARTIST=InYourPhaze; Mantra Flow
COMPILATION=1
DATE=2010
GENRE=Electronic
REPLAYGAIN_TRACK_GAIN=-2.11 dB
REPLAYGAIN_TRACK_PEAK=0.51782227
TITLE=By the Base
TRACKNUMBER=7
TRACKTOTAL=8
stozher
Re: Re-scan music folders / umlaut problem
Postby DXTR66 » Tue Oct 09, 2012 5:08 pm
Is it possible that this is still an issue?
At least I noticed the same problem with my library (using subsonic 4.7).
By the way - is there another way of reporting bugs? (eg JIRA, Bugzilla,...so that someone could vote for a bugfix?) :)
DXTR66
Postby BKKKPewsey » Tue Oct 09, 2012 6:31 pm
Any artist starting with an international character goes in "#" section eg
Änglagård
Íon
Ólöf Arnalds
Öxxö Xööx
Øresund Space Collective
This is the same for 4.7 as 4.6
Postby DXTR66 » Thu Oct 11, 2012 6:23 am
@BKKKPewsey: Might be true, I can't say ;). But what I can say for sure is that none of my artists nor albums show up if they have an umlaut somewhere in the middle of the name. Eg: "Die Ärzte".
It showed up once I changed the Ä to Ae...but that is not really an option in my opinion.
Am I the only one experiencing this problem?
DXTR66
Postby strontjonk » Fri Oct 12, 2012 6:50 am
Interesting, I actually have no problems with an 'umlaut' at all... an in fact, it was the reason I switched from streaming my music via Winamp/AjaxMP3 to SubSonic.
I also have "die Ärzte" in my library and they - as BKKKPewsey mentioned - show up under the '#' section. Note that the leading 'die' can be filtered off under the settings > gerenal > "Articles to ignore"
Does the folder appear when you rename "Ae" back to "Ä"?
strontjonk
Postby qupfer » Tue Feb 19, 2013 2:43 pm
a small additional note
If you filtered "der die das" and want "die Ärzte" a shown in the A-Group, you have only to cange the "Index Configuration" from
A B C D....
to
A(AÄ) B C D
So Artists with a leading A and leading Ä will visible together.
You can change the Index-Line to A Ä B C too.
And sorry for my english
qupfer
Postby strontjonk » Wed Mar 06, 2013 1:16 pm
It's done for (X-Z) in a similar way; did not know you could this for Ä and related characters as well. Great additional note, qupfer, thanks!
strontjonk
Postby DXTR66 » Sat Jan 11, 2014 5:19 pm
I'm bumping this now because I still have this issue. Maybe someone could shed some light what the probem could be?
I just upgraded the server software to 4.8, but the issue is still the same :(.
Here are some details about my installation:
Subsonic 4.8 (war package), running on a tomcat 6.0.20
Tomcat is running on my qnap nas...
An example file which does not work: Die Ärzte (live) - 3-Tage Bart.mp3
Last thing: Umlauts in ID3 tags work like a charm..just all files including umlauts don't work. If i change the name from the file, the umlaut can still be in the id3 tag and will be shown correctly by all clients.
DXTR66
Users browsing this forum: No registered users and 61 guests
