[Solved] Problem After Upgrade
Postby WelcomedRain » Mon Nov 29, 2010 1:34 am
I just upgraded to Subsonic 4.2. I am running 64bit Ubuntu 10.10 and have not been able to connect to my music since the upgrade. I have checked the port forwarding on my router to make sure that still shows 4040 and it does. I am trying to use Subsonic on the desktop on which it and my music library is located (so this is not an attempt to connect remotely)... I get the following message when entering "http://localhost:4040/".... "HTTP ERROR: 404 NOT_FOUND RequestURI=/index.view Powered by Jetty://"
Any ideas/suggestions? I appreciate any help you can give... I would also like to let you know that Subsonic is the only music player I use. I use it on my iPhone, remotely at work and even on my home computers. It is a great program and a great system. Thank you.
UPDATE: Mysteriously, Subsonic has started working again. I'm not sure why it stopped working after the upgrade or how it came to work all of a sudden but things are back to normal as if there was never any problem. Thanks!
WelcomedRain
re
Postby pcs800 » Mon Nov 29, 2010 8:11 pm
This is the exact same thing I and others are experiencing on windows machines. The difference is that mine has NOT started working mysteriously.
Any help from anyone would be MUCH appreciated, particularly since I have donated :-)
pcs800
