Changing the default 'cover.jpg to 'folder.jpg"
Postby j3tblk » Tue Nov 30, 2010 4:06 am
I've got an easy one this time. Any and all help is greatly appreciated.
The default settings for changing cover art is 'cover.jpg'
This is really messing me up and I'm sitting for hours renaming things.
How\Where do I change this to 'Folder.jpg'?
Thanks!!
j3tblk
Postby j3tblk » Tue Nov 30, 2010 2:58 pm
That's the mask it has nothing to do with how the file is written.
Mine is already set to that and it still saves the art as cover.jpg and not folder.jpg.
(I am on 4.2 you may be running an older version which used to save the cover art as folder.jpg by default.)
j3tblk
Postby j3tblk » Tue Nov 30, 2010 3:02 pm
clininja wrote:try this batch file & folder renamer app works on linux & win32
http://file-folder-ren.sourceforge.net/
I already use "ReNamer" I dont need a batch rename as 600 some odd gigs is already fine...It's the new stuff I need saved as folder.jpg. Plus renaming adds another step when the file should just be saved as folder.jpg instead of cover.jpg in the first place. The program is pulling the word "cover" from somewhere I need to know where that is and change it...problem solved.
j3tblk
