Can load SS from Android but not from remote browser
Postby walrus » Tue Nov 30, 2010 3:45 pm
I think this may be related to the upgrade, but I thought I'd see if anyone else had this problem. SS is working on my home PC, as I can connect from my Android, but I can't load from my browser at work (unfortunately they force us to use IE7). I CAN load the SS demo, so I know it's not an issue of IT blocking anything. Any tips?
-Steve C.
-Steve C.
walrus
Postby darkuni » Tue Nov 30, 2010 4:42 pm
Have you tried using your IP address directly instead of your subsonic.org address?
darkuni
Postby walrus » Tue Nov 30, 2010 6:15 pm
Yep. Same result (on both phone and remote PC).
-Steve C.
walrus
Postby stennie » Tue Nov 30, 2010 7:34 pm
When using your phone at home, are you on wifi or 3G?
Just a note that reinstalling/updating Subsonic resets the assigned port. If your ISP is blocking port 80, then you'll need to set a new port and possibly update your router to match it.
stennie
Postby walrus » Tue Nov 30, 2010 9:04 pm
Hmm, i'll try that, although the port has always been set to 80 with no problems.
I'm using 3G on my phone.
-Steve C.
walrus
