Date Created Issue
Date Created Issue
Postby colli419 » Tue Nov 30, 2010 10:22 pm
Hi All:
I would like to be able to use the Newest function on the home screen, but I am having the following problem. When I look at this tab the same folders are always displayed even when I upload new media. The reason for this is that they are reported as being created in the year 2046. The strange thing is when I look at the files in explorer it gives the right date of creation (or at least in this decade). I know this is a strange, and potentially unique problem, but does anyone have any ideas on how I could fix this? I have included a screenshot to show the behavior.
colli419
Postby GJ51 » Wed Dec 01, 2010 1:51 am
You'll be fine in 36 years, or you might try doing a manual search update.
Go to Settings/Search thern click on Update search index now.
Hope it helps.
Postby Exrace » Thu Dec 02, 2010 3:37 am
What are the times in the rest of the app?
I knew subsonic was cool but I didn't think it could time warp? :)
Exrace
Postby colli419 » Fri Dec 03, 2010 1:27 am
Thanks for the replies, but I have already updated the search index multiple times and it stays the same. As for the times in the rest of the app, I am not exactly sure what you mean? Are you are referring to the album data shown when browsing? Unfortunately Subsonic doesn't allow you to modify the created date. And I am not sure how to do it in Linux, frankly because I didn't think that the file system stored that data. I am thinking it is a problem with the way that Subsonic is reading the data on the file, because it shows up correctly when I look at it in explorer (for instance). At this point I am at a loss, but would really like to use this functionality. Please help!
colli419
Postby stozher » Fri Dec 03, 2010 2:51 am
My be this help... Move album out from SS music folder. Update search index. Move album back to SS and update search index again.
stozher
Postby colli419 » Wed Dec 08, 2010 9:19 am
So I tried your idea stozher, and when it was gone it was removed from the Newest pane, however as soon as I put it back in the SS folder it came back just like before. Here is the log message:
[12/8/10 3:16:19 AM CST]   DEBUG   SearchService   Logically undeleting info for album /var/subsonic/media/Music/Breakbot. Found on disk.
It's almost as if the index wasn't really updated, but rather bandaged when the file was removed, and subsequently unbandaged when I put it back.
colli419
Postby stozher » Wed Dec 08, 2010 2:10 pm
Stop server. Remove /var/subsonic/subsonic12.index. Start server...
stozher
