installed but went to localhost address and didnt work..
Postby deannemarie09 » Wed Dec 01, 2010 1:12 am
i installed subsonic on my windows computer and went to the site it told me to log on and to put admin in as password and username but all i got was a wrong username/password error... Help.
deannemarie09
Postby GJ51 » Wed Dec 01, 2010 2:01 am
How are you trying to access the site? On the system where SS is installed, right click on the SS icon in the task bar tray and select Open SS in Browser.
admin
admin
is correct unless you changed it. Deleting the SS directory and doing a reinstall should reset everything back to default.
Do you have latest Java installed? Install both 32 and 64 bit on 64 bit machines to use 64 bit browser.
