ip address
ip address
Postby columbiabbs » Fri Dec 03, 2010 3:14 am
dont know why subsonic.org is redirecting my ip to 97.74.125.134
my ip address is 24.88.76.61 this is where subsonic should go.
please check this out.
thanks wt.
columbiabbs
Postby alphawave7 » Fri Dec 03, 2010 4:47 am
I'm getting a login page on the 24.x.x.61 address, so it seems to be working.
Postby GJ51 » Fri Dec 03, 2010 8:13 am
Hi WT,
I'm not getting a logon for the site.
Oops! Google Chrome could not connect to 24.88.76.61:4040
ops! Google Chrome could not connect to 97.74.125.134:4040
is what I get.
http://columbia.subsonic.org/ should translate to the IP address assigned by your ISP and the port number for the server.
Check your router to see if your ISP has changed your external IP address. If this is what has happened, SS needs to be refreshed to use the new IP address.
If you send me a pm with your external ip address, I'll be happy to test it for you.
Postby alphawave7 » Sat Dec 04, 2010 12:48 am
Yes..it worked last night after you posted, but now is not working.
Postby Exrace » Sat Dec 04, 2010 1:14 pm
Confirm your outside ip with http://www.whatismyip.com/
You will need to do this from the PC that is running subsonic.
Exrace
