Certain songs won't play
Postby pashko » Sun Dec 05, 2010 7:52 pm
Hello... Since yesterday, I have been having a problem. Certain songs will not play and this is the error I get:
12/5/10 10:49:02 AM PST] DEBUG TranscodeInputStream Starting transcoder: [/Library/Application Support/Subsonic/transcode/lame] [-S] [-h] [--resample] [44.1] [-b] [192] [--tt] [I'm So Lonesome I Could Cry (Hank Williams)] [--ta] [Me First And The Gimme Gimmes] [--tl] [Love Their Country] [/Users/Shared/My Music/Me First And The Gimme Gimmes/Love Their Country/07 I'm So Lonesome I Could Cry (Hank Williams).mp3] [-]
[12/5/10 10:49:02 AM PST] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/lame) dyld: unknown required load command 0x80000022
And on my iPhone it states:
"It looks like the trial period for use of API on this Subsonic server is over. The web interface will continue to work. Please donate to the Subsonic project to get a license key. Visit subsonic.org to details. Please note that this donation goes to the developer of Subsonic, not iSub."
I have already donated and registered, but did so again once I got above error, with no change. I don't mind donating again, as I love this app, but just want it to play ALL songs. The same songs that won't play on the web/gui interface are the same songs that won't play on my iPhone.
Any suggestions??
pashko
Postby pashko » Mon Dec 06, 2010 2:12 am
OK.... Turns out the songs that were not playing were the ones that are bigger than my 'maxbitrate'. I found my issue on this page:
http://forum.subsonic.org/forum/viewtopic.php?t=4746&highlight=dyld+unknown+required+load+command+0x80000022
And here is the entry from Barretta that helped me figure what was wrong:
barretta wrote:I'm having a lot of problems upgrading to 4.2 on Mac OS X.5. First, getting major errors with transcoding.
Error logs spit out:
On my android I get:
Prepare failed.:status=0x1 (IOException)
If I try to do a clean install, I get this error on startup from the subsonic Control Panel:
java.lang.IllegalArgumentException: Bad temp directory: /Library/Application Support/Subsonic/jetty/1944
It seems that 4.2 fails to create all the necessary components in the Subsonic directory (such as the jetty folder). Am getting all the same errors with the beta release as well.
I'm not getting any of these problems with 4.1 and unfortunately am having to downgrade now. Also, I don't seem to be getting any problems running 4.2 on Ubuntu.
So I went ahead and downgraded to 4.1 on my Mac and all is good now. Hopefully this will get fixed in 4.3....
pashko
