How Do I Stream Using Windows OS ?
Postby naan-kadavul » Wed Dec 08, 2010 12:30 am
Hi people,
I have installed subsonic version 4.1
http://192.1XX.X.3:8000/
http://localhost:8000/
Actually what is local host ? Is it my IP address, or subnet mask, or default gateway ?
When i go rename my url local host to ip address, its bringing to me to a login page. How can I Stream my playlist to world wide web ?
Someone help.
naan-kadavul
Postby naan-kadavul » Wed Dec 08, 2010 12:33 am
Ok, greatfully i have found my ip in cmd/ipconfig.
Now.. the question is how can i stream it. I am playing songs in subsonic. in music folder. Now how can my friends listen to it ?
naan-kadavul
Postby naan-kadavul » Wed Dec 08, 2010 12:54 am
port is also successfully done.
Status: Successfully forwarding port 8000.
Now how can I stream it, ? How can I make my friends listen to the radio.
There should be something like link or script for that right ?
I want to put the player in my site, and let everyone here my radio.
naan-kadavul
Postby seanpkeown » Sat Dec 11, 2010 4:29 am
You might get a better response by posting under the help forum.
http://forum.subsonic.org/forum/viewforum.php?f=2
~ Sean K
seanpkeown
Postby GJ51 » Sat Jan 22, 2011 7:49 pm
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Test your setup by entering your external IP:port# to see if it connects. e.g. http://24.88.76.61:8080/ If it works, you're good to go.
