Cover Art not showing
Postby mynameisfiber » Thu Dec 16, 2010 5:00 pm
Out of the blue, most of my cover art stopped being displayed! When I try to look at the image, I am taken to this page: http://jsfiddle.net/NzkdV/. The log says things like:
[12/16/10 11:52:58 AM EST] WARN CoverArtController Failed to create thumbnail for /data/Music/Queens of the Stone Age/Songs for the Deaf/cover.jpg
Does anyone have an idea of what went wrong? I am running the subsonic server on Linux (Ubuntu, 10.10 amd64)
mynameisfiber
Postby Exrace » Sat Dec 18, 2010 1:25 pm
Maybe a permissions problem?
Have you tried a restart of subsonic?
Exrace
Postby Saiboogu » Sat Dec 18, 2010 3:37 pm
I had problems with thumbnails and graph generation (from the status page) recently -- Turns out that while I had installed Sun Java, I was still using openjdk as a default. I had to run
sudo update-alternatives --config java
and select Sun Java. Probably just removing openjdk and installing Sun would do the trick too.
Saiboogu
