Subsonic wont connect at all
Postby Jumpbear » Sat Dec 18, 2010 12:43 am
hi there. I have been having this problem with subsonic for the last couple months. Not sure what's going on.
Basically I keep trying to start it, and it says it is running but the icon stays red and I cant get it to connect. Not sure why.
Here are my log files:
Subsonic-service.log
16 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@b753f8: display name [org.springframework.context.support.ClassPathXmlApplicationContext@b753f8]; startup date [Fri Dec 17 16:31:23 PST 2010]; root of context hierarchy
64 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
331 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@b753f8]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1fc6e42
340 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1fc6e42: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
357 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files (x86)\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\1946
386 [main] INFO org.mortbay.log - jetty-6.1.x
680 [main] INFO / - Initializing Spring root WebApplicationContext
680 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
703 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@61a907: display name [Root WebApplicationContext]; startup date [Fri Dec 17 16:31:24 PST 2010]; root of context hierarchy
736 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
789 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
822 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
838 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@61a907]: org.springframework.beans.factory.support.DefaultListableBeanFactory@9c2715
901 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@9c2715: defining beans [playerDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,daoHelper,musicFileService,securityService,settingsService,searchService,luceneSearchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheManager,userCache,musicFileCache,childDirCache,coverArtCache,musicFolderCache,chatCache]; root of factory hierarchy
941 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
1272 [main] INFO org.springframework.cache.ehcache.EhCacheManagerFactoryBean - Initializing EHCache CacheManager
Dec 17, 2010 4:31:24 PM net.sf.ehcache.CacheManager addShutdownHookIfRequired
INFO: The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
Dec 17, 2010 4:31:24 PM net.sf.ehcache.Cache initialise
WARNING: Cache: musicFolderCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
WARNING: Cache: chatCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
1601 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
1607 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
1607 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
1607 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
1621 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 941 ms
1676 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
1677 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
1678 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@1555185: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Fri Dec 17 16:31:25 PST 2010]; parent: org.springframework.web.context.support.XmlWebApplicationContext@61a907
1678 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
1720 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@1555185]: org.springframework.beans.factory.support.DefaultListableBeanFactory@bd93cd
1778 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@bd93cd: defining beans [leftController,rightController,statusController,mainController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMusicFileInfoController,setRatingController,randomPlaylistController,loadPlaylistController,savePlaylistController,changeCoverArtController,nowPlayingController,searchController,settingsController,playerSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,searchSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playlistController,xspfPlaylistController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,downloadController,donateController,multiController,wapController,restController,dbController,savePlaylistValidator,donateValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,localeResolver,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@9c2715
2078 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 401 ms
3090 [main] WARN org.mortbay.log - failed org.mortbay.jetty.nio.SelectChannelConnector$1@a50da4
java.io.IOException: Unable to establish loopback connection
   at sun.nio.ch.PipeImpl$Initializer.run(Unknown Source)
   at sun.nio.ch.PipeImpl.<init>(Unknown Source)
   at sun.nio.ch.SelectorProviderImpl.openPipe(Unknown Source)
   at java.nio.channels.Pipe.open(Unknown Source)
   at sun.nio.ch.WindowsSelectorImpl.<init>(Unknown Source)
   at sun.nio.ch.WindowsSelectorProvider.openSelector(Unknown Source)
   at java.nio.channels.Selector.open(Unknown Source)
   at org.mortbay.io.nio.SelectorManager$SelectSet.<init>(SelectorManager.java:279)
   at org.mortbay.io.nio.SelectorManager.doStart(SelectorManager.java:201)
   at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:308)
   at org.mortbay.jetty.Server.doStart(Server.java:228)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:101)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:58)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
   at java.lang.reflect.Constructor.newInstance(Unknown Source)
   at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
   at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher$1.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: connect
   at sun.nio.ch.Net.connect(Native Method)
   at sun.nio.ch.SocketChannelImpl.connect(Unknown Source)
   at java.nio.channels.SocketChannel.open(Unknown Source)
   ... 47 more
3092 [main] WARN org.mortbay.log - failed SelectChannelConnector@0.0.0.0:80
   ... 47 more
3097 [main] WARN org.mortbay.log - failed Server@4dd1b
   ... 47 more
   ... 47 more
3126 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
4137 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
4225 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.0.10:9412](local),objID:[0:0:0, 0]]]]
subsonic.log
[2010-12-17 16:31:24,364] INFO DaoHelper - Checking database schema.
[2010-12-17 16:31:24,637] INFO DaoHelper - Done checking database schema.
[2010-12-17 16:31:24,819] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sat Dec 18 03:00:00 PST 2010
[2010-12-17 16:31:24,873] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Dec 17 16:36:24 PST 2010
[2010-12-17 16:33:39,174] INFO NetworkService - Successfully forwarding port 100.
[2010-12-17 16:36:24,883] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-12-17 16:36:24,884] INFO PodcastService - Completed scheduled Podcast refresh.
Any help would be appreciated. Thanks :)
And if you need anything else. Just ask.
Jumpbear
Postby GJ51 » Sat Dec 18, 2010 4:22 am
Platform? OS? SS ver.?
Postby Jumpbear » Tue Dec 21, 2010 2:57 am
Sorry, I've been busy the past couple days and completely forgot about this.
Running on W7 x64. Using the newest version of subsonic (4.2 I believe).
Jumpbear
Postby GJ51 » Tue Dec 21, 2010 5:22 am
http://monroeworld.com/android/subsonic/
Follow the tips in this tutorial in the link above.
DO NOT use port 80. 8080, 8081,8082 ... work fine.
Do not use pnp router setup. Manually configure your router. Use a static rout to assign yor server computer an internal ip at the high end of the range, out of the way of DHCP. 192.168.1.254 works well if there's nothing else there.
Match the ip definition on the properties for the NIC on the computer.
After reading the tutorial - carefully, let us know if you still have questions.
