Subsonic Setup Issues
Postby varunsrin » Fri Dec 24, 2010 11:15 pm
So I just installed an instance of subsonic, and it works by accessing localhost
However, it seem that my Belkin N+ router will not forward the ports - I've tried to set up ports 8080 and port 80 (both TCP and UDP) to be forwarded to my computer, but whenever I try to access it via <IP Address>:8080 it just times out.
Any suggestions on how to troubleshoot this further? I've tried almost everything I could think of
varunsrin
Postby alphawave7 » Fri Dec 24, 2010 11:30 pm
Your address comes back as Trial Expired.
Postby varunsrin » Fri Dec 24, 2010 11:48 pm
the address I am using is valirus.subsonic.org
varunsrin
Postby alphawave7 » Sat Dec 25, 2010 4:52 am
When logged in to SS and settings, in Network, does it show as successfully forwarding your chosen port? Is 'automatically configure' checked or unchecked?
Postby varunsrin » Sat Dec 25, 2010 10:46 pm
Yes, but it say successfully configured on port 80, even when I have the subsonic-agent run on port 8080.
When I type in valirus.subsonic.org within my network it resolves to the ocal TP - 192.168.1.4 but when I type it in from outside the network it resolves to my public facing IP and times out.
varunsrin
Postby alphawave7 » Sun Dec 26, 2010 1:06 am
It sounds as if you have a corrupted install (service parameters aren't matching the Properties folder). I'd try deleting the c:/subsonic folder, and re-installing. After install, set the port using the console, stop service/restart service and then try opening the port in the router.
