Subsonic won't create new players
Postby gabbott » Sat Dec 25, 2010 4:46 pm
I'm running 4.2 on unraid. The problem is I have a player created for my login gabbott for my android device. The problem is when I log into that login via a browser it is using the player for my android device and not creating a separate player so it will work via the broswer.
Any ideas?
gabbott
Postby GJ51 » Sun Dec 26, 2010 7:06 pm
Delete all players. Logging in should then create a new player automatically. There is no need to create a player for Android. SS will do it when you log on through the phone.
Postby gabbott » Sun Dec 26, 2010 9:30 pm
GJ51 wrote:Delete all players. Logging in should then create a new player automatically. There is no need to create a player for Android. SS will do it when you log on through the phone.
I'll try that, thanks. Yeah it did create a player for my android phone, the problem is when I login through the web browser it is using the player for my android phone which isnt working out too well.
gabbott
Postby anttin » Tue Dec 28, 2010 12:42 am
I noticed that when I login with Chrome the player isn't created. It works with Firefox.
anttin
