Need help setting up music folder located in a home server
Postby tomasito » Fri Dec 31, 2010 5:50 pm
I heard good reviews of the subsonic, and the advantge it has with audio galaxy. I dwonload the setup program last night.
My massive music collection is stored in a HP mediasmart home server.
I have been trying to setup the music server. I am unable to set it up since last night.
I have no music files in my local computer where the subsonic is installed.
I am getting frustrated with the setup.
explorer shows \\myservername\music, I inputted this to the add music folder and hit save . it gave me the error "internet explorer can not display webpage"
I am stuck, need assistance,
Roberto
tomasito
Postby GJ51 » Fri Dec 31, 2010 6:06 pm
Install Subsonic on the WHS. In settings/music mask just enter d:\Music once you have SS on the homeserver. That way you can access your SS site by using servername.homeserver.com:port address of the SS install. Works great and allows you or friends/family to share! :D
Postby tomasito » Fri Dec 31, 2010 10:12 pm
how do I install the subsonic into the WHS. I went into the add in menu. But I tried to drag the program, it will not allow me to do it.
is there another subsomic program that is an add in?
tomasito
Postby tomasito » Fri Dec 31, 2010 10:37 pm
I did a little internet google search. It looks like that I need to use the .war program, and it will be deployed using tomcat.
I think it is over my head with this.
Is there an easier way of doing this?
tomasito
Postby mfalzon » Fri Dec 31, 2010 10:37 pm
You need to actually install it on the server. Remote in and install it. Its not a what addons so you can install it though the whs connector app
mfalzon
Postby jaquense » Fri Dec 31, 2010 10:47 pm
My family runs it's own music "server" which amounts to little more then a shared music folder on one of the 4 household windows computers. Sometimes I want access to their music along with my own (which is on my subsonic server)
I have been successful with mounting the it to a home music folder and then just using a local path in subsonic /home/me/networkmusic or something like that.
which keeps you from having to install the server on the music comp itself. However, the speed is abysmal from off the local network laptop->desktop->music is a bunch o connections
jaquense
Postby GJ51 » Sat Jan 01, 2011 12:51 am
Subsonic can be easily installed on WHS through Remote desktop connection. I'm currently out of town, but I will be happy to assist with installation next week when I return home.
If you are already familiar with how to access WHS through RDC, just install Java and Subsonic on the C: drive and point the music folders to your libray on the D: drive.
EDIT: In the meantime, read this:
http://monroeworld.com/android/subsonic/
Postby tomasito » Sat Jan 01, 2011 3:51 am
Hello GJ51,
installation by remote in, is new to me. I only know how to do add in.
I will read up on the link that you gave me.
As soon as you come back. Let me know for sure I will need assistance in installing the subsonic.
thanks,
tomasito
Postby utopian » Sat Jan 01, 2011 1:09 pm
i have it installed on my WHS.. Do a n RDP session to your WHS by its Ip address.. run the install prog and then point your music to its folder location on the WHS d:/music possibly ??
utopian
Postby tomasito » Sat Jan 01, 2011 4:38 pm
here is the setup that I have at home.
Music is stored is the HP mediasmart server (800GB Flac files)
There are 4 desktop computers at home - 2 window vista and 2 window XP
The goal: To be able to stream music into my vibrant android phone
I tried installing the subsonic in one of the computers, didn't work.
I was advised that I need to install the subsonic directly in the HP mediasmart.
The HP mediasmart server has it's own remote access. Inside , it has a folder called "software" , in this folder it has the following folder
"add ins"
"Home PC restore CD"
"Home server connector software"
"Mac"
Question:
How do I proceed in installing the subsonic?
what version of the subsonic should I use -
Stand-alone version
WAR version
windows installer version
I also read that I need to use Tomcat to install the subsonic. Some say that I also need to include Java.
This is getting to be technically confusing. I don't want to mess up my home server too much data information in it.
tomasito
WHS and subsonic
Postby whimpyjones » Sat Jan 01, 2011 5:08 pm
Check out my post in this thread. It is an older step by step for installing tomcat and subsonic on WHS v1 (not the beta Vail). Everything should still be the same.
http://forum.subsonic.org/forum/viewtop ... highlight=
whimpyjones
Postby tomasito » Sat Jan 01, 2011 8:27 pm
thanks , I will read the thread
tomasito
Postby tomasito » Sun Jan 02, 2011 2:04 am
i have an HP EX487 mediasmart. one of the links stated that this tutorial is for custom built WHS. Because it stated that the EX48series aleady has the tomcat installed.
I went into the software folder of the EX487, I do not see a tomcat folder.
I have to read up more
tomasito
