Issue with displaying Unicode characters (Greek)
Postby samaklis » Sun Jan 02, 2011 7:44 pm
Hi, I have a list of mp3 files that are in UTF (Greek). The files display fine in terminal, file manager on my ubuntu server, but it seems that the subsonic server I just installed on the same server displays them with all question marks and refuses to add them to play them or add them to any play list.
Is this a known limitation with the software? I found only a couple of unanswered posts on this topic, so I am wondering if this is something that is being addressed.
Most of my music is Greek, so the proper display of the characters is very important for me.
samaklis
Postby stozher » Sun Jan 02, 2011 9:56 pm
Change en_US.utf8 with Greek locale!
http://forum.subsonic.org/forum/viewtopic.php?p=17900#17900
http://forum.subsonic.org/forum/viewtopic.php?p=18917#18917
For example my "/etc/default/subsonic":
export LANG="en_US.utf8"
export LANGUAGE="en_US.utf8"
export LC_CTYPE="en_US.utf8"
SUBSONIC_ARGS="--home=/srv/subsonic --port=80 --max-memory=512 --default-music-folder=/srv/subsonic/Music --default-podcast-folder=/srv/subsonic/Podcast --default-playlist-folder=/srv/subsonic/Playlists"
On my server (WWW link bottom) all work fine (see artist "π=m²" - Greek letter pi)
stozher
Postby samaklis » Mon Jan 03, 2011 1:01 pm
This did it.
Thanks for the reply.
samaklis
Postby stozher » Mon Jan 03, 2011 6:01 pm
This day I test Jetty and Tomcat servers from Debian repository and see in "/etc/init.d/..." daemon startup scripts:
# Make sure Subsonic is started with system locale
if [ -r /etc/default/locale ]; then
    . /etc/default/locale
    export LANG
fi
I include this code in "/etc/default/subsonic" (replace "export ..." from above my post). In next release must be included to "/etc/init.d/subsonic" after variable declarations.
Also I replace in "/usr/share/subsonic/subsonic.sh"
${JAVA} -Xmx${SUBSONIC_MAX_MEMORY}m \
with
${JAVA} -Djava.awt.headless=true -Xmx${SUBSONIC_MAX_MEMORY}m \
  -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode \
"Use '-XX:+UseConcMarkSweepGC' to enable the CMS garbage collector (improved response time). If you use that option and you run Subsonic on a machine with exactly one CPU chip that contains one or two cores, you should also add the '-XX:+CMSIncrementalMode' option." (cite from "/etc/default/tomcat6")
stozher
Postby sindre_mehus » Fri Jan 07, 2011 12:55 pm
Thanks, I've added the /etc/default/locale thing in Subsonic 4.3.
