Can connect over home wifi, but not Sprint 3G or 4G
Postby huff009 » Tue Jan 11, 2011 12:47 am
I have set up my subsonic account and am able to connect when I am on my wifi connection, however, I can not connect to the server when using 3G or 4G. I can, however, connect to the demo server with no issues.
On my Settings/Network page, it says it is successfully forwarding to port 80. It also tells me my subsonic.org address is registered but it can not connect to it.
Having read some other posts here, I am thinking I have a port issue. Problem is, I don't know what to do with that information. I would appreciate any input you have that might help me.
Thanks.
huff009
Postby GJ51 » Tue Jan 11, 2011 2:39 am
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
In Subsonic Settings/Network - UNCHECK " Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding)." make sure to hit the SAVE button, you may have to scroll down to see it depending on your screen size.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Test your setup by entering your external IP:port# to see if it connects. e.g.
http://24.88.76.61:4040/
If it works, you're good to go.
Postby eqwalker » Tue Jan 11, 2011 9:37 pm
Also, you may want to reference my previous post further down on my issue of streaming just fine on my home WiFi but not able to connect on 3G (Verizon). Mine turned out to be the port I was using. I changed it and all is well.
eqwalker
Postby teknojnky » Wed Jan 12, 2011 4:08 am
subsonic connects fine for me on my EVO on both 3g and 4g, I'm using port 4040.
the upnp mapping and subsonic redirector works fine for me also, using dd-wrt/wrt-54
teknojnky
Postby huff009 » Thu Jan 13, 2011 6:37 am
So, here's another question.
I am following the guide for setup. I have uninstalled subsonic and I started over. I am at the point where I am having to "Put Subsonic PC on static IP".
My questions is, once I do this do I need to reconfigure all of my devices to access my router for wifi (e.g. phone, xbox, etc.)?
I am not computer illiterate by any means, but I have never played around with network settings of this nature before. Also, is there any risk to having a static IP address?
Thanks.
huff009
Postby GJ51 » Thu Jan 13, 2011 8:00 am
NO, you do not have to reconfigure all devices on the network. First, you shoud read through all the documentation for your router and at least gain an overview understanding of the basic functions and setup. All routers are slightly unique and have different menus, but they all do the same basic network functions. If you provide us with your routers mfgr. and model # it is easy enoguh to download the manual and answer any specific questions you might have.
If you've read through what I've provided so far, it may take more than one read through to get a real grasp of what's going on. It is detailed and often confusing information that can be a bit duanting the first time you try to get your feet wet in the network management pool, but as I've posted many times, if you're into Subsonic, your more than likely going to be expanding your home network as time goes on, and there's no time like the present to start learning, unless you can afford the Geek Squad, who probably can't do it anyway.
Basically, I recommend manually assigning the internal IP address of the computer that will host Subsonic, so that DHCP will never reassign it a new address and thus break all the connections that you'll set up in the router to forward the port that Subsonic will use to communicate with the internet. Think of your network as an apartment building with 255 apartments that can have several people in each apartment. Think of the port number as the name of a person in the apartment building. When the doorbell rings, the mailman tells you he has a delivery for port 8080 (just an example) but he doesn't know which apartment it goes to. The router then uses the port forwarding table to tell the mailman that 8080 lives in the apartment located at 192.168.1.254 (again an example). This way the request is handed to the correct computer, which when it sees that it is a request on port 8080, it triggers a response from the Subsonic service which is just sitting by the door listening for a request for 8080 (the Subsonic service). When the service gets the incomming request, it passes it to the program and processes the requested information and triggers the program to send the requested data back to the computer that requested it. It is a singular operation that does not affect the other devices on your network. If you plug in a new computer, or connect a laptop over Wifi, the router will function normally and use DHCP to automatically assign internal addresses to the new devices. The reason you want to assign an address to the computer hosting Subsonic at the upper end of the router's range of addresses, is to eliminate the possibility of the router assigning that computer's IP address to a new device thus breaking the communication link to Subsonic. It doesn't always happen, but it's an issue that's worth avoiding. I've spent many long hours troubleshooting network issues only to find, surprise, surprise the router assigned the same address to two different computers, or just changed an address arbitrarily.
Remember, the more specific your questions and the more information you provide describing your hardware and software platform, the better will be the answers you get from other users who know the process.
Postby huff009 » Fri Jan 14, 2011 6:02 am
Alright. Thank you so much for your help. I started over completely with a fresh install of program and phone app. I followed all the directions precisely (even though I often had no idea what I was doing) and I now seem to be up and running.
This is great, and I really appreciate your time, patience and help.
Thanks again
Chris
huff009
