Update standalone version from 4.2 to 4.3
Postby sherlock » Thu Jan 13, 2011 4:01 pm
Hi all!
Is there a howto for the update process from 4.2 to 4.3 for the standalone version? I´m either loosing my old data or the merged version is damaged and does not start.
Thanks in advance!
sherlock
Postby sherlock » Sat Jan 15, 2011 1:48 pm
Do I have to create a clean installation and then copy the old folders and files (which ones?) or vice versa?
sherlock
Postby Poffa » Sat Jan 15, 2011 2:13 pm
You might want to specify your OS.
http://www.subsonic.org/pages/installat ... standalone
This is for Linux, but I guess you could to pretty much the same if you're running Mac or Windows: http://forum.subsonic.org/forum/viewtopic.php?t=2231
Poffa
Postby sherlock » Sat Jan 15, 2011 4:07 pm
I was sure I did exactly the same steps but after repeating the tutorial it seems to work. Thanks a lot...
sherlock
