showing wrong time in chat [Resolved]
Postby Rauna » Thu Jan 13, 2011 8:55 pm
Hi.
I am getting the wrong time in chat, it shows my time +2 hour.
My freenas server is showing the right time.
Where do i change the timezone in subsonic?
Thank you
Rauna
Postby bushman4 » Fri Jan 14, 2011 1:11 pm
The time comes from the server that is running Subsonic. In my case, that is a Windows Home Server. I just did a test, and changed the time up two hours, and the chat messages showed the new time.
Where do you have Subsonic running?
Glenn
Postby Rauna » Fri Jan 14, 2011 1:51 pm
I am running a freenas server, and i have tried to change the time on it but it does not help.
The freenas server is showing the correct time
Kenneth
Rauna
Postby Rauna » Thu Jan 20, 2011 8:43 am
Closed
I have find the problem
Rauna
Postby bushman4 » Fri Jan 21, 2011 4:42 pm
What was it?
Glenn
Re: showing wrong time in chat
Postby evilnone » Tue May 01, 2012 3:25 pm
I am having this problem on my server. I am running it on a CentOS and the date and hwclock commands show the correct time, however the chat message time is +2hr. I noticed this was resolved but not explained how it was fixed. Any input on what I can do to fix this?
Edit: I am running subsonic 4.4
evilnone
Postby evilnone » Tue May 01, 2012 5:22 pm
I solved this problem.
In case anyone else has it in the future and finds this thread... I had to set the localtime on my server (/etc/localtime) to the correct setting (for me it was EDT). After I did that I updated the date and hwclock to the correct time and it was solved.
evilnone
