Video streaming with transcode not working
Postby manwithaplan » Tue Jan 18, 2011 11:00 pm
Running 4.3 on a Mac OSX Server 10.6.6 on Mac Mini. I can use video if I don't transcode, but it stutters a bit. These are Handbrake rips of BluRays that I own. I typically use Handbrake's AppleTV2 preset btw.
More importantly, when I let SS try to transcode, I get the Video not found or access denied, with a big long string of Hex. I've checked my /transcode directory and have both ffmpeg there and lame, so not sure what I need to do here. I had started a while back with version 4.1, then loaded 4.2, now 4.3.
Here is a sample log from Bourne Identity...
[2011-01-18 17:54:13,369] INFO VersionService - Resolved local Subsonic version to: 4.3
[2011-01-18 17:54:13,665] INFO VersionService - Resolved latest Subsonic final version to: 4.3
[2011-01-18 17:54:13,665] INFO VersionService - Resolved latest Subsonic beta version to: 4.4.beta1
[2011-01-18 17:54:25,038] INFO PlaylistInputStream - brian listening to "Movies/TheBourneIdentity-BluRayipad.m4v"
[2011-01-18 17:54:25,063] DEBUG TranscodeInputStream - Starting transcoder: [/Library/Application Support/Subsonic/transcode/ffmpeg] [-v] [0] [-ss] [0] [-async] [30] [-i] [/Users/Shared/Video/Movies/TheBourneIdentity-BluRayipad.m4v] [-f] [flv] [-b] [1000k] [-r] [30] [-s] [848x360] [-acodec] [copy] [-]
[2011-01-18 17:54:25,115] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) FFmpeg version SVN-r25203-einsteinx2, Copyright (c) 2000-2010 the FFmpeg developers
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) built on Sep 26 2010 02:08:29 with gcc 4.2.1 (Apple Inc. build 5664)
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) configuration: --prefix=/Volumes/Ramdisk/ --as=yasm --extra-version=einsteinx2 --disable-shared --enable-static --disable-ffplay --disable-ffserver --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-libspeex --enable-bzlib --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-nonfree --enable-version3
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libavutil 50.28. 0 / 50.28. 0
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcore 0. 9. 0 / 0. 9. 0
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcodec 52.90. 0 / 52.90. 0
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libavformat 52.78. 5 / 52.78. 5
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libavdevice 52. 2. 2 / 52. 2. 2
[2011-01-18 17:54:25,118] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libavfilter 1.45. 0 / 1.45. 0
[2011-01-18 17:54:25,119] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libswscale 0.11. 0 / 0.11. 0
[2011-01-18 17:54:25,119] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2011-01-18 17:54:25,204] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) [mov,mp4,m4a,3gp,3g2,mj2 @ 0x1809600] max_analyze_duration reached
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg)
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 1000.00 (1000/1)
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/Shared/Video/Movies/TheBourneIdentity-BluRayipad.m4v':
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) major_brand : mp42
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) minor_version : 0
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) compatible_brands: mp42isomavc1
[2011-01-18 17:54:25,205] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : HandBrake 0.9.5 2011010300
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Duration: 01:58:17.45, start: 0.000000, bitrate: 859 kb/s
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.0: start -0.083000, end 388.179000
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 00
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.1: start 388.179000, end 514.847000
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 01
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.2: start 514.847000, end 698.531000
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 02
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.3: start 698.531000, end 818.359000
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 03
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.4: start 818.359000, end 1183.307000
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 04
[2011-01-18 17:54:25,206] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.5: start 1183.307000, end 1541.039000
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 05
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.6: start 1541.039000, end 1755.462000
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 06
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.7: start 1755.462000, end 2196.319000
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 07
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.8: start 2196.319000, end 2636.759000
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 08
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.9: start 2636.759000, end 2907.738000
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 09
[2011-01-18 17:54:25,207] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.10: start 2907.738000, end 3112.234000
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 10
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.11: start 3112.234000, end 3721.467000
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 11
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.12: start 3721.467000, end 4201.655000
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 12
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.13: start 4201.655000, end 4724.928000
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 13
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.14: start 4724.928000, end 5040.035000
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 14
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.15: start 5040.035000, end 5500.161000
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 15
[2011-01-18 17:54:25,208] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.16: start 5500.161000, end 5919.288000
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 16
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.17: start 5919.288000, end 6313.307000
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 17
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.18: start 6313.307000, end 6693.895000
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 18
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.19: start 6693.895000, end 7097.414367
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 19
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(und): Video: h264, yuv420p, 1024x432 [PAR 135:136 DAR 40:17], 689 kb/s, 23.98 fps, 1k tbr, 90k tbn, 180k tbc
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16, 164 kb/s
[2011-01-18 17:54:25,209] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.2(und): Subtitle: text / 0x74786574
[2011-01-18 17:54:25,212] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) [buffer @ 0x1101ca0] w:1024 h:432 pixfmt:yuv420p
[2011-01-18 17:54:25,212] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) [scale @ 0x11135e0] w:1024 h:432 fmt:yuv420p -> w:848 h:360 fmt:yuv420p flags:0xc0000004
[2011-01-18 17:54:25,223] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[2011-01-18 17:54:25,223] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,223] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : Lavf52.78.5
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.0: start 0.000000, end 388.179000
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 00
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.1: start 388.179000, end 514.847000
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 01
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.2: start 514.847000, end 698.531000
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 02
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.3: start 698.531000, end 818.359000
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 03
[2011-01-18 17:54:25,224] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.4: start 818.359000, end 1183.307000
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 04
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.5: start 1183.307000, end 1541.039000
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 05
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.6: start 1541.039000, end 1755.462000
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 06
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.7: start 1755.462000, end 2196.319000
[2011-01-18 17:54:25,225] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 07
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.8: start 2196.319000, end 2636.759000
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 08
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.9: start 2636.759000, end 2907.738000
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 09
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.10: start 2907.738000, end 3112.234000
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 10
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.11: start 3112.234000, end 3721.467000
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 11
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.12: start 3721.467000, end 4201.655000
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 12
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.13: start 4201.655000, end 4724.928000
[2011-01-18 17:54:25,227] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 13
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.14: start 4724.928000, end 5040.035000
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 14
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.15: start 5040.035000, end 5500.161000
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 15
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.16: start 5500.161000, end 5919.288000
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 16
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.17: start 5919.288000, end 6313.307000
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 17
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.18: start 6313.307000, end 6693.895000
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 18
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Chapter #0.19: start 6693.895000, end 7097.414367
[2011-01-18 17:54:25,228] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) title : Chapter 19
[2011-01-18 17:54:25,229] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(und): Video: flv, yuv420p, 848x360 [PAR 1:1 DAR 106:45], q=2-31, 1000 kb/s, 1k tbn, 30 tbc
[2011-01-18 17:54:25,229] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: libfaac, 48000 Hz, stereo, 164 kb/s
[2011-01-18 17:54:25,229] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream mapping:
[2011-01-18 17:54:25,229] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[2011-01-18 17:54:25,229] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
[2011-01-18 17:54:25,229] DEBUG InputStreamReaderThread - (/Library/Application Support/Subsonic/transcode/ffmpeg) Press [q] to stop encoding
manwithaplan
