Podcasts - Set up six of them and now can not Delete
Postby grenex » Wed Jan 19, 2011 8:48 pm
I set up several podcast stations (Six to be exact) and now I can not Delete or add any more. The options to add/delete podcasts are missing from the screen.
How can I fix this? I searched the install files to see If i could manually edit one of them to remove a couple, but no luck.
grenex
Postby stozher » Thu Jan 20, 2011 3:05 am
http://forum.subsonic.org/forum/viewtopic.php?p=18560#18560
stozher
Postby grenex » Thu Jan 20, 2011 3:20 am
I stopped the server and removed the folder ".../subsonic/jetty/XXXX/jsp
It did not resolve the issue. The add/remove/download options for podcasts still do not show.
grenex
Postby stozher » Thu Jan 20, 2011 3:48 am
Are you sure log-in as admin or your current users have access to podcast administration (Settings / Users - User is allowed to administrate Podcasts)?
stozher
Postby grenex » Thu Jan 20, 2011 3:55 am
Yes, I am logged in as the admin
grenex
Postby stozher » Thu Jan 20, 2011 4:24 am
Check from other computer or with different browser. If you edit some jsp files - original files is included in zip archive subsonic.war . Just copy to desktop, rename war to zip extension and unzip (default location for Linux is a /usr/share/subsonic/subsonic.war; for Windows my be find in Program Files; or download your war or standalone version from SS site).
After reverting of some jsp files you need to stop server, clear Jetty cache (above link in my previous post)...
stozher
Postby grenex » Fri Jan 21, 2011 3:26 am
stozher wrote:Check from other computer or with different browser. If you edit some jsp files - original files is included in zip archive subsonic.war . Just copy to desktop, rename war to zip extension and unzip (default location for Linux is a /usr/share/subsonic/subsonic.war; for Windows my be find in Program Files; or download your war or standalone version from SS site).
There are no .war files on my PC in the installed directory of the app
I followed steps above again to stop sevice, remove jetty subfolder, resart service, and use a new browser on a diff machine. Still no checkboxes/buttons to control the podcasts. :(
grenex
Postby stozher » Fri Jan 21, 2011 12:00 pm
Post screenshot...
stozher
Postby grenex » Fri Jan 21, 2011 5:43 pm
As per your request, here is the screenshot of the screen maximized and not showing the options to manage the podcasts
grenex
Postby stozher » Fri Jan 21, 2011 6:15 pm
:lol: No right scrollbar... Click on Podcast icon with right mouse button and choice "Open Link in New Tab" or open new tab and enter address:
http://.../podcastReceiver.view?
stozher
Postby grenex » Fri Jan 21, 2011 6:20 pm
Already a few steps ahead of you. I tried to open it in a new window before even posting here and have same results. Below is a screenshot of having right clicked on podcast and using "open in new window"
grenex
Postby stozher » Fri Jan 21, 2011 6:20 pm
Also open ".../subsonic/db/subsonic.script" with plain text editor and find those rows:
INSERT INTO USER_ROLE VALUES('admin',1)
INSERT INTO USER_ROLE VALUES('admin',2)
INSERT INTO USER_ROLE VALUES('admin',3)
INSERT INTO USER_ROLE VALUES('admin',4)
INSERT INTO USER_ROLE VALUES('admin',5)
INSERT INTO USER_ROLE VALUES('admin',6)
INSERT INTO USER_ROLE VALUES('admin',7)
INSERT INTO USER_ROLE VALUES('admin',8)
INSERT INTO USER_ROLE VALUES('admin',9)
INSERT INTO USER_ROLE VALUES('admin',10)
stozher
Postby stozher » Fri Jan 21, 2011 6:24 pm
Check also this in same file:
INSERT INTO ROLE VALUES(1,'admin')
INSERT INTO ROLE VALUES(2,'download')
INSERT INTO ROLE VALUES(3,'upload')
INSERT INTO ROLE VALUES(4,'playlist')
INSERT INTO ROLE VALUES(5,'coverart')
INSERT INTO ROLE VALUES(6,'comment')
INSERT INTO ROLE VALUES(7,'podcast')
INSERT INTO ROLE VALUES(8,'stream')
INSERT INTO ROLE VALUES(9,'settings')
INSERT INTO ROLE VALUES(10,'jukebox')
stozher
Postby grenex » Fri Feb 04, 2011 1:25 pm
yes, both of those lines exist in the file
grenex
Postby stozher » Fri Feb 04, 2011 1:42 pm
Send me ".../subsonic/jetty/XXXX/webapp/WEB-INF/JSP/podcastReceiver.jsp" or reinstall (just stop SS and rename ".../subsonic/jetty" to "jetty.bak").
stozher
Users browsing this forum: No registered users and 72 guests
