4.3 Problem with MP3 and Jukebox
Postby pdeckert » Sat Jan 22, 2011 6:50 am
I have an interesting bug.
I can play all my MP3's using Web Player, External Player fine.
However when I use Jukebox, which I use most of the time, (stream music through the house), Some albums do not play, just silence!
I fixed this by un-checking all the Active Transcodings for Audio
EG: wav > Mp3 , flac > mp3 etc.
The music plays now through the Jukebox, but it often stutters or pauses?
Any idea, I have checked MP3 headers on the songs and as mentioned before the MP3's play fine on winamp, Win Media Player etc. and locally through Subsonic on the desktop.
Any help please.
Regards,
Peter Deckert
(I love Subsonic)
pdeckert
Postby 3R3 » Tue Jan 25, 2011 3:28 pm
i have a similar problem. only here the jukebox doesnt work at all. everything else works. this is on ubuntu 9.04 with SS 4.3 stable. log looks like this
[25.01.11 16:26:48 MEZ]    INFO   JukeboxService   Starting jukebox player on behalf of dave
[25.01.11 16:26:48 MEZ]    DEBUG   JukeboxService   stateUpdated : OPENING:-1:java.io.BufferedInputStream@7df2d5
[25.01.11 16:26:48 MEZ]    INFO   PlaylistInputStream   dave listening to "Die Bestie in Menschengestalt/Die Ärzte - 12 - Die Allerschürfste.mp3"
[25.01.11 16:26:49 MEZ]    DEBUG   JukeboxService   opened : {mp3.id3tag.track=12, mp3.crc=false, mp3.copyright=false, album=Die Bestie in Menschengestalt, mp3.id3tag.length=204600, mp3.channels=2, mp3.version.mpeg=1, date=1993, mp3.id3tag.genre=Punk Rock, mp3.framesize.bytes=413, author=Die Ärzte, title=Die Allerschürfste, mp3.version.layer=3, mp3.vbr.scale=100, mp3.bitrate.nominal.bps=275000, mp3.version.encoding=MPEG1L3, audio.type=MP3, mp3.id3tag.v2=java.io.ByteArrayInputStream@14a6474, vbr=true, mp3.id3tag.v2.version=4, mp3.padding=false, audio.framerate.fps=38.28125, audio.channels=2, mp3.framerate.fps=38.28125, mp3.header.pos=15543, mp3.frequency.hz=44100, basicplayer.sourcedataline=org.classpath.icedtea.pulseaudio.PulseAudioSourceDataLine@120344f, bitrate=275000, mp3.mode=1, mp3.vbr=true, audio.samplerate.hz=44100.0, mp3.original=true}
[25.01.11 16:26:49 MEZ]    DEBUG   JukeboxService   stateUpdated : OPENED:-1
[25.01.11 16:26:49 MEZ]    WARN   JukeboxService   Error in BasicPlayer.play()
3R3
Postby pdeckert » Wed Jan 26, 2011 12:40 pm
My media PC is windows 7
This is an annoying bug.
pdeckert
Postby pdeckert » Fri Jan 28, 2011 12:23 am
I assume that silence mans it's an un-fixable bug.
Very annoying not being able to play all my music in jukebox mode.
pdeckert
Postby pdeckert » Tue Feb 08, 2011 4:04 am
Worked out the BUG and a fix.
I found that if a cover image is saved with the MP3 and that image is large then the MP3 will not play in Jukebox mode.
So my work around is to remove the image stored in the MP3 or replace it with a smaller image. I found that up to 220x220 seems to be OK.
Strange BUG the work around seems to solve it.
Still Love SubSonic!!!!!
Peter Deckert....
pdeckert
