Removing users
Removing users
Postby slw7920 » Sat Jan 22, 2011 3:33 pm
Hi all; did a search on this but couldn't find anything so here goes. How do you remove users you no longer want to have access to your stuff? Thanks in advance.
slw7920
Postby GJ51 » Sat Jan 22, 2011 5:56 pm
Settings/Users - Select User from list
Check box "Delete the user"
Click "Save"
Postby slw7920 » Sun Jan 23, 2011 1:11 am
GJ51 wrote:Settings/Users - Select User from list
Click "Save"
:oops: Thanks GJ51; if I had scrolled down a little farther I would've seen that. Thanks!
slw7920
Postby GJ51 » Sun Jan 23, 2011 5:20 am
Yeah, the scroll down thing gets just about everybody until you get used to the SS interface. Do a lot of browsing and scrolling to get familiar with all the options and settings. Once you get used to it, everything works great.
