Android app cuts off songs on shuffle
Postby jdkoeppen » Mon Jan 24, 2011 5:47 am
I've noticed an odd issue where on shuffling some songs will cut off and skip to the next track about a minute in as though they're not fully downloaded. However, after going back to check the track again manually (by finding the album in the media library) the song is still only partially there, it will play for about a minute then stop, even after refreshing the library.
I've checked the tracks on my home system and on the web server and the track is fine there.
Why does the Android app cut songs off and how to I do a hard refresh of the library to get the full song back?
jdkoeppen
Postby NssOne » Tue Jan 25, 2011 8:17 am
I can confirm as I have had at least a similar, if not the same, issue myself. It will sometimes play a song and cut it off in the middle of it. Then there's an issue message in the notification bar. This was on a Droid 1 with Android 2.2.
NssOne
Postby TylerDK » Tue Jan 25, 2011 12:45 pm
+1
TylerDK
