subsonic on suse 10 cant get it working
Postby vega77 » Tue May 23, 2006 1:23 pm
when i try to access: http://localhost:8080/subsonic/
i get this message:
HTTP Status 404 - /subsonic/
type Status report
message /subsonic/
description The requested resource (/subsonic/) is not available.
Apache Tomcat/5.0
I'm using suse 10 i386.
t first i got some permisson errors when starting tomcat manually.
but i changed ownership to tomcat:tomcat.
tomcat now starting without error.
vega77
Postby sindre_mehus » Tue May 23, 2006 3:03 pm
Difficult to say, but apparently the Subsonic war file hasn't been deployed properly. Please check that <TOMCAT>/webapps directory contains both "subsonic.war" file and a "subsonic" directory (the latter is created automatically by Tomcat).
-Sindre
Postby Guest » Wed May 24, 2006 9:00 am
I have bout subsonic.war and a subsonic directory in:
/srv/www/tomcat5/base/webapps
Guest
Postby sindre_mehus » Wed May 24, 2006 6:09 pm
Hm, maybe it's related to the permission problem you mentioned earlier. Try the following:
1. Stop Tomcat
2. Remove the /srv/www/tomcat5/base/webapps/subsonic directory
3. Start Tomcat
4. Go to http://localhost:8080/subsonic/ and if that fails, try http://localhost:8080/subsonic/index.jsp
If you still have problems, have a look in the logs in /srv/www/tomcat5/base/webapps/logs.
You could also try to upgrade to the latest Tomcat version.
Hope this helps :-)
Postby vega77 » Fri May 26, 2006 9:32 pm
can you recommende a linux distro for use with subsonic ?
I'm currently planning on upgrading my filserver and add subsonic too it.
So i'm flixible in choice of distro.
vega77
Postby sindre_mehus » Sun May 28, 2006 3:07 pm
Any distro should work. I don't have a Linux system myself, so I can't really recommend one in particular.
However, I strongly recommend to install the latest version of Tomcat.
Good luck,
