[fixed] Jukebox silent (player hanging or crashing)
Postby nlmarco » Tue Jan 25, 2011 3:30 pm
Hello *,
I tried the stable release 4.3 as well as the 4.4.beta1 of subsonic. Playing music in the browser works fine, but the jukebox does not work at all :( The behaviour is the same with both versions. I downloaded the *.deb packages and use an Ubuntu 10.04.1 LTS server (64 bit).
More precisely, the server stays silent - no sound at all. The UI switches to "Stop" as if it was playing, but I hear nothing. And it stays like this - it neither switches to the next song of the playlist (even though a 3 minute song should be finished after 15 minutes) nor does the "Stop" switch to "Play" again.
Looking into the log file /var/subsonic/subsonic_sh.log shows this:
14411 [btpool0-5] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0.116.rc1 on jetty-6.1.x / JDK 1.6.0_20 from Sun Microsystems Inc. at
23481 [btpool0-7] INFO javazoom.jlgui.basicplayer.BasicPlayer - open(java.io.BufferedInputStream@5f0772d2)
23503 [btpool0-7] INFO javazoom.jlgui.basicplayer.BasicPlayer - Create Line
23503 [btpool0-7] INFO javazoom.jlgui.basicplayer.BasicPlayer - Create Line : Source format : MPEG1L3 44100.0 Hz, unknown bits per sample, stereo, unknown frame size, 38.28125 frames/second,
23504 [btpool0-7] INFO javazoom.jlgui.basicplayer.BasicPlayer - Create Line : Target format: PCM_SIGNED 44100.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
23533 [btpool0-7] INFO javazoom.jlgui.basicplayer.BasicPlayer - Line : com.sun.media.sound.MixerSourceLine@5460eb0c
23534 [btpool0-7] INFO javazoom.jlgui.basicplayer.BasicPlayer - startPlayback called
23534 [btpool0-7] INFO javazoom.jlgui.basicplayer.BasicPlayer - initLine()
Nothing more - no exception, no warning.
In order to find a solution, I browsed the forum for quite a while and read dozens of threads, but nothing helped. I do use Sun Java (version 1.6.0_20). I do have flac, faad et al installed (all symlinks in /var/subsonic/transcode/ point to existing executables), I do have permissions to write to the sound card (subsonic runs as root according to ps aux | grep java) and there is no exception message like in many of the threads discussing jukebox problems.
The only thread that helped a bit further is this: http://forum.subsonic.org/forum/viewtopic.php?t=2038
The command 'aplay -l' gives me this result:
root@myserver:~/install/subsonic# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: ALC888 Analog [ALC888 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: SB [HDA ATI SB], device 1: ALC888 Digital [ALC888 Digital]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: ATI HDMI [ATI HDMI]
Subdevices: 1/1
And when I compile & run this little java class, I see this:
root@myserver:~/install/subsonic# java audioDevList
Available mixers:
SB [plughw:0,0]
SB [plughw:0,1]
SB [plughw:0,2]
HDMI [plughw:1,3]
Java Sound Audio Engine
Port SB [hw:0]
Port HDMI [hw:1]
So I tried playing around with the settings in /usr/lib64/jvm/java-6-sun/jre/lib/sound.properties and had some success after adding these lines:
javax.sound.sampled.Clip=#SB [plughw:0,1]
javax.sound.sampled.Port=#Port SB [hw:0]
javax.sound.sampled.SourceDataLine=#SB [plughw:0,1]
javax.sound.sampled.TargetDataLine=#SB [plughw:0,1]
With these settings, the log looks differently:
455940 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - open(java.io.BufferedInputStream@10c7eb9d)
455962 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Create Line
455962 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Create Line : Source format : MPEG1L3 44100.0 Hz, unknown bits per sample, stereo, unknown frame size, 38.28125 frames/second,
455962 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Create Line : Target format: PCM_SIGNED 44100.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
455966 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Line : com.sun.media.sound.DirectAudioDevice$DirectSDL@102e6640
455966 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - startPlayback called
455966 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - initLine()
456006 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Open Line : BufferSize=88200
456007 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Master Gain Control : [-80.0,6.0206] 0.625
456007 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Pan Control : [-1.0,1.0] 0.0078125
456007 [btpool0-2] INFO javazoom.jlgui.basicplayer.BasicPlayer - Creating new thread
456007 [BasicPlayer] INFO javazoom.jlgui.basicplayer.BasicPlayer - Thread Running
1221661 [BasicPlayer] INFO javazoom.jlgui.basicplayer.BasicPlayer - Stream closed
1221662 [BasicPlayer] INFO javazoom.jlgui.basicplayer.BasicPlayer - Thread completed
If I play a song, after a few minutes (when the song finished) the next song is picked from the playlist. Unfortunately though, everything is still silent. I assume that is, because the device "SB [plughw:0,1]" is my digital output - however I do not have digital sound equipment and my sound system is connected via the analogue connector.
Note, that I do not have two sound cards! That's just one ordinary on-board device which seems to offer both analogue and digital output.
Well, I give up for now - please let me know if there is anything else I can try! For example: Can I use an external player app (e.g. mpg123 & ogg123) instead of the internal java player? Or can I change the configuration to use another java player class? Or is it possible to change the behaviour of the player - e.g. to suppress sth. that makes it hang up (e.g. querying the gain)?
Btw. note, that I can play sound just fine with other applications - including java apps (!) - on this server. Only subsonic fails to use the sound card :(
Best regards, Marco :)
nlmarco
Postby nlmarco » Mon Jan 31, 2011 5:30 pm
Hello *,
yabbadabbadoo! I got it running!
I decided to give it another try, restarted my server (because I suspected something to be hanging), installed the 4.4.beta1 again (which I deinstalled after I didn't get it running last week) and suddenly it worked!
I don't know what was the problem. No configuration change at all (I reverted the fancy changes in my Java's sound.properties already last week).
nlmarco
Postby Jesus Army » Fri Apr 29, 2011 7:38 am
I just got the same problem. But, difference is that is was working fine, and the few days later Jukebox became silent (For the all 3 users that I created)
Server is running on Windows 7 for info, not ubuntu like you.
As I am using it only for a week, I was thinking about the last changes I did. Well, I tried to organize the players of a user, and I also added some music folders to the library. For that user, I deleted all players, but Subsonic did never wanted to create a new one uppon login. It was a test user so it did not bothered me so much, and I gave up. But after seeing that Jukebox was not working for every user, I tried to figure this problem out. Using another browser helped to create a new player after login. So I recreated a Jukebox player for that user and now Jukebox is finally working ! Well only for that user, but at least I have got one working... (Creating other Jukebox player for other user does not change anything for now...)
So for info, maybe it is a good idea to check if you have a user without any player in case you got this problem...
Hope it will help others who got this problem !
Jesus Army
