router problem
router problem
Postby paparay » Fri Jan 28, 2011 1:58 pm
After many hours I finally got Subsonic to work. It was finding the router port and I was able to add my music folders. I turned off computer last night and when I started it this morning it could not open port on router. PF Port Checker confirms that the port is being used by another program. I have also set up port forwarding manually in my router. It seems that the problem is the port setting in Subsonic Control Panel. That is set at 4040. That is the only way I can get Subsonic to configure port 4040 in router. If I change to port 80 in control panel then when Subsonic page opens it wants to configure port 80. I prefer to solve these problem without seeking help but I totally stumped.
Thank you,
paparay
Postby GJ51 » Sat Jan 29, 2011 3:05 am
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Default Transcoding for video:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Stozher: mp4 > flv transcoding:
ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
