speed limit settings
Postby disgustipated » Fri Jan 28, 2011 2:29 pm
is anyone having issues with limiting the amount of bandwidth being used for uploading? I have a total of 512 for my upstream and i am trying to limit it to half of that for uploading streams with subsonic. i have under advanced upload and download limit set them to as low as 25 even and im watching my network utilization from the pc i have subsonic running and its still using around 450kbps for uploading the stream. i am using the beta release though so not sure if that might be part of it.
disgustipated
Postby stozher » Fri Jan 28, 2011 6:14 pm
Limits is available only for download albums or files and upload from "More" section. Streaming isn't limited and no option for this.
stozher
Postby disgustipated » Fri Jan 28, 2011 6:43 pm
interesting, i will have to try to set this up in my router then under qos....
i will probably be putting in a feature request for this
i dont see what you mean under the more section though, the setting i was referring to was under settings > advanced
disgustipated
Postby stozher » Fri Jan 28, 2011 6:56 pm
SS top menu: ... Settings Status More ...
stozher
Postby GJ51 » Fri Jan 28, 2011 7:40 pm
stozher wrote:SS top menu: ... Settings Status More ...
I don't see anything on the More screen for setting limits on my Windows install.
EDIT: Found it.
It's on Settings/Advanced.
Postby disgustipated » Fri Jan 28, 2011 7:59 pm
EDIT: Found it.
yeah it must be a versioning thing since im using the windows/standalone install and thats where mine was. wasnt sure if it was somewhere else and it doesnt look like it
disgustipated
