TRanscoding FLAC>MP3
Postby samotano » Fri Mar 30, 2007 9:35 pm
I get erratic behaviour when trying to play flac tracks. I have setup the transcoder, however, some flac tracks are transcoded to mp3 and play fine in winamp, others don't play (winamp says buffering but nothing happens). It does not seem to be a file size problem, nor file names format.
Any ideas?
thx
samotano
Problem Solved
Postby samotano » Sun Apr 01, 2007 7:07 pm
Just to follow-up on my previous post. I was able to solve my problem of decoding FLAC tracks in subsonic. If anyone else has this problem, here is what worked for me.
The error log indicated the following:
2007-04-01 11:20:45,189] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\flac) Ibrahim Ferrer - Aquellos Ojos Verdes.flac: ERROR while decoding data
[2007-04-01 11:20:45,189] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\flac) state = FLAC__STREAM_DECODER_READ_FRAME
The file plays just fine in winamp (without subsonic). However, if I try to decode it to .wav or test it in Flac I get the error:
by using the -F switch I can decode it "through errors", meaning it will ignore the error and keep on decoding. At the end of the decoding, Flac indicates the following: "ERROR, MD5 signature mismatch". I don't know yet what this error means, but it's not serious enough to make the file unreadable (perhaps the metadata is the culprit?).
In any case, I just needed to add the -F option to my flac>mp3 transcoding settings in subsonic. Yippie!
samotano
Postby sindre_mehus » Wed Apr 04, 2007 12:57 pm
Excellent, thanks for letting us know!
I'll update the default transcoding settings according to your findings.
Users browsing this forum: No registered users and 87 guests
