Why am I forced to change server daily? (Router issue?)
Postby senator_kelly » Fri Jan 28, 2011 5:15 pm
I am using subsonic and it seems every day, sometimes more than once a day, I lose connection. So I am forced to change my server from xxxx1.subsonic.org to xxxx2.subsonic.org it happens so frequently that I've just started implementing a number system to make the change easier.
Typically when I make the change, subsonic will work again. I'm guess this has something to do with my router at home. What change do I have to make to my router to guarantee an uninterrupted connection to subsonic from my phone?
I don't know a lot about routers/port forwarding, but if someone could just point me in the right direction, I can figure it out.
THANKS!
senator_kelly
Postby disgustipated » Fri Jan 28, 2011 6:55 pm
it depends on your isp, if youre losing your connection and your modem automatically reconnects then most likely you will get a new ip address. while some isp's will allocate the ip address for a long period of time, some assign a new ip on each new connection.
I would be more curious as to why you appear to possibly not have a solid internet connection.
disgustipated
Postby GJ51 » Fri Jan 28, 2011 7:56 pm
What port are you using?
Is your server at home on a fixed ip address or is it assigned it's internal ip by DHCP on the router?
Postby senator_kelly » Fri Jan 28, 2011 9:30 pm
The port I am currently using is 5588, but I end up changing that every few days anyway. It may be a false-positive, but I do it to help get back connectivity.
I believe the address is assigned my DHCP. For example, every time I restart my computer, it has a different IP address.
So I'm guessing I need to set up a static IP address for my computer? Maybe forward the port correctly? Not really sure how to do these things.
senator_kelly
Postby GJ51 » Fri Jan 28, 2011 9:32 pm
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Test your setup by entering your external IP:port# to see if it connects. e.g. http://24.88.76.61:8080/ If it works, you're good to go.
Default Transcoding for video:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Stozher: mp4 > flv transcoding ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
Also, read the manual for your router.
